Attachment 561044
Attachment 561045
Hope this gives a better picture
Richard
Attachment 561044
Attachment 561045
Richard
Two pics from my '67 library. Doesn't look like Haul's.
Attachment 561046Attachment 561047
Don't really see any residual "sombrero left on gas tank supports metal. Wish I had better pics.
Richard,
correct…you have seen it.
all original 65, but missing the front traverse…;)
br
haulo
Here are some shots of 301382:
Attachment 561064
Attachment 561065
Attachment 561066
There's "sombrero" on the gas tank and a little bit of "sombrero" on the trunk floor in front of the gas tank.
Interesting. Thanks all for sharing. Feels like quite an involved procedure. Wonder why they had the sombrero extend to the suspension pan. I know the later thanks were tar sealed. Wonder if it had anything to do with that.
Probably, the question is why they did not continue the practice. The later thanks have the pebbled top surface but the finish (schutz) of the fron suspension pan did not change as far as I know. Was the foam seal on the earlier cars also tarred before installation?
Since '67 was painted over with schutz I wonder id Franz's mould could be used. Wax the interior of the mould and then use a couple of coats of Flex Seal hand layered by brush. Only going to be covered up anyway. Who knows. Buy enough Flex Seal and you could also seal all your basement windows and make a row boat too. Also enhance your model railroad scenes.
