Should water be in there?
Hi Guys!
I'm new to this forum (and Porsche ownership) so I'm not sure if this topic has been covered before...
Anyway, I have a 73 911E with RS upgrades etc. I have only had this car for a few months so I'm still regularly going out to the garage to swoon. Since going over the car carefully, I noticed a build up of water in the well under the trap door in the luggage compartment. Is this normal? After further investigation I found a metal blanking plate at the bottom of the well which allowed me to drain out this water. Once the area was dry I checked the metal and lucky everything was ok. No rust! After washing the car the well was again full of water. Strange! There seems to be some kind of plastic "drain" moulding going from the lower windscreen vents to the edge of the trap door cover. This part is cracked. Could this be the problem? If so, are these parts still available and how difficult are they to replace?
Thanks for your time!
Stuart
