Want to buy the pictured straight 22mm threaded fitting. Only the threaded part. Not the hose or the collar.
Need one or two.
Aluminum or steel, but prefer aluminum.
Have alloy collars to trade if interested.
Rory rgalla9146@aol.com
Need one or two.
If you change your mind.
FS-914-6 GT-Oil Fitting,Tch,DN20, M30x1.5, Male, 901.107.813.04, $82.74 per assembly
Attachment 614783
Thank you for the offer.
I'm going to see if there will be other replies.
Why is it referred to as a 914-6 GT part ?
My car isn't a 914 6 GT...AFAIK !
This same fitting is used in 2 different hoses. One for the the 914-6 GT and the other for the stock 914-6.
The 914-6 GT hose shown above is NLA. The application for the 914-6 is still available:
PET '70-'76 914 Fig. 1-04-00, #19/1 901.107.823.03 Hose line, Intake pipe (Tank-Engine Cooler) Qty: 1 PCNA List 2024: $297.62
Will the nipple in the kit you are offering thread into the original collar in my picture ?
If so can I buy just two of the nipples alone ?
I want to use them with the original dated collars on my 914 6 (forty years and counting)
Thank you for your help.
Rory
If Jimmys doesn't work try Brad Davis
Rory, I believe you can harvest what you need from this.
Most Porsche oil hoses have 2 female ends. These hose fittings have a male end which allows them to connect to another hose on the way to their destination. Their limited usage leads to their rarity. The most common solution keeping cars on the road is adding an M30 union to one end of a female-female hose.
Attachment 614898
Rory:
I used to sell fitting components separately, but differences in the subsequent anodizing runs led to mismatched assembly finishes. The photo above is a good example of the difference between male and female hose inserts as well as anodizing differences.
Rick the piece you show has an adapter attached.
I need the hose end fitting that your bare piece would attach to.
Some of these terms can be confusing.
You are offering a male (with adapter attached) I need a female hose end
Thank you for offering
Rory
PS I need the upper piece in Jimmys last post
Oh, yes clear to see. I’ll keep looking
