The first thing we did was a basic vacuum and wipe down the interior. I also went about taking the bubbled limo tint off. I couldn't wait to get it off.
Attachment 569936
Before:
Attachment 569937
After:
Attachment 569938
Attachment 569939
Attachment 569936
Before:
Attachment 569937
After:
Attachment 569938
Attachment 569939
Any plans for working on the car this weekend?
Hey Drew, check out this Article:
http://www.ludwigs-pferdewelten.de/i...rtwig-steenken
The girl on the first photo was the first owner of your car.
Here is my plan for the near term process of getting the car back on the road. A little background on the car: the reason it was initially taking off the road was the brakes going out. That's the only piece of information we have. The engine does turn over when the crank is turned.
1. Get the car started
- Clean out the fuel system to get rid of the bad gas. Replace line ect.
- Oil change
- Marval mystery oil soak
- Spark plug change
- Get a battery
- Sort out electrical system. There is something going on with a motorcycle throttle in the engine bay. Very strange.
2.Then the task will be getting it driving
- The clutch pedal is completely locked up.
- Shift throws are extremely long. Linkages need to be tightened up. Not sure what that fully entails yet.
- The gas pedal seems to be falling apart.
- Brakes are not working. We will need all new lines. Fix anything else in the system that needs it.
- Need new muffler. The one on the car is damaged
- Figure out what the webers need. simple kit rebuild or full send out service for refurb.
- New tires
If anyone has other tasks please feel free to share. Things like H1's, front turn signals, rear turn signals, ect will have to take a back seat to these other task.
In other news
zhivago found an article which contains a picture of the original owner. Ever since seeing the Kardex I've wondered who she is and it is very exciting to put a face to the name.
Attachment 569976
Lastly, the 68 plates came in the mail today. Once it can pass inspection I will use these plates on the car. A little rust on them like Casper
Attachment 569977
The chances of that article are crazy. She moved to Switzerland, perhaps you’ll have luck reconnecting with her. Best of luck sounds like a solid plan. Perhaps also try checking the battery boxes that they arent sitting in battery acid…
Drew,
Your initial list seems to cover most of the basic systems. I suspect that you also need to replace some of the parts in the suspension system.
Best,
Ravi
Awesome find and persistence pays off - also amazing to see the photo of the first owner!
Good luck in your journey!
We worked a bit today on the car. Got the fuel tank out. Definitely had some bad gas in it (see the red bucket). We also got the rear up on stands for better access. We put together a list of fuel system parts that will be required. The car does not have a fuel pump so I will be on the hunt for one. Earlier in the week, I took off the aftermarket facelift license plate panel. I will be on the hunt for an imperfect panel to put on for now. Also, I did a bit of research because the air filter housing that came with the car looks different than it should. It turns out it is off a '65-66 so I will be looking to sell that while looking for the correct one. The one I have is date stamped 4/65.
Attachment 570685
Attachment 570686
Attachment 570687
Attachment 570688
Attachment 570689
Attachment 570690
Attachment 570691
Attachment 570692
