I have a 72 911T. The sticker on the cover of the engine fuse cover is missing. from top to bottom, what is the fuse amperage and what does each fuse control. FWIW, I have the single stage rear defogger if that makes a difference
I don't believe there was a sticker, the fuse info is embedded on the inside of the cover if memory serves me right.
If mounted correctly, the engine fusebox should be in the order of position 3,2,1 from top to bottom.
Position 3 should have a black/red wire and a red wire on either side. It is an 25 Amp fuse. The red (a thicker red wire than the same side one that goes to fuse position 1) comes from the starter motor and is always live. The red/black goes to rear window defogger relay.
Position 2 should have a red/white on one side. The other side is bridged to position 1. It is an 8 amp fuse. The red/white goes to the cold start valve relay (for MFI) and the speed relay for the anti-backfire function for MFI.
Position 1 should have a red wire coming to it and nothing leaving. This is a 5 amp fuse (if anything is actually installed) and is supplied by switched power from the ignition switch via the 10 fuse panel in the frunk. Not sure what accessory it is used for. I've usually seen no fuse in this position.
Ravi
Position 1 is for the Sportomatic switch, terminated with a blue/yellow wire on 70/71’s.
Actually, I don't believe there was a cover for the engine fuses in 72/73. The big plastic cover with the two knurled knobs over the whole rear console was all that was provided. I think I asked about this once in my build thread.
Ravi
Yes and that was stuck on the inside of the plastic cover but suspect it didn't stay there for long as only ever seen one original which is what my copy was made from
Clyde,
I wonder how many of us have run off to check :D :)
Plenty I suspect but unlikely that anyone has found one intact!!!
Yours should have wingnuts just in case you have knurled screws.
I have wingnuts. We had the discussion on the board during by build. But the consensus was there would be no cover on the 3 fuse holder back there if I recall.
Ravi
Correct Ravi
Yes I have seen those too much better idea than paper that falls off due to heat.
'69S, pretty much the same as Boyers picture, except no Amperage designations. Just in case you have never seen one.
Very important, don't EVER loose one of those screws! 4.5 mm X .75 pitch and a rounded end. You will never find one of those, and will end up buying another fuse panel to get one.
Bob B
Attachment 579230
Attachment 579231
Attachment 579229
