That tail could be correct for late build 76 model. My 77 Aus del c3.0 has all rubber that came with sport option.
Gentlemen,
somewhere in the back of my mind I have the idea that the C3-engine has weaknesses (crank?), but cannot find any written proof. Could you please confirm or dispel that notion! Thank you!
I have engine # 6770431 and am wondering if there is a chance the original car is still in existence??
http://i1260.photobucket.com/albums/...psxcwbfhvb.jpg
http://i1260.photobucket.com/albums/...psye7ntinm.jpg
Actually finalizing my 3,0 Carrera engine.
Already running smooth.
There are some small detail I would like to get fixed and only little picture of original engine compartments available.
1. how many brackets had been used for the long heater hose?- have mounted one, but there are three different versions listed in PET
2. when was the change from old style ignition coil to the one with the tabs close together?- found both version with a date code of early 76 in my stock
3. how does the electric engine panel look like? -it´s the larger board with five round relay hols and the later 3 pin CDI, thats all I know
4. There had been 120 engines with 210PS instead of 200PS. Which engine numbers are known with 210PS?
I have resurrected the Carrera 3.0 Registry. It is bare bones for now, will add to it as I get time. It will just have the cars listed for now. Please head there to sign your car up if you haven't already. Thanks! www.carrera30.net
