I have a tired 2.2T engine that i would like to pull apart and reseal this winter and figured I would do a top end on it. Looking for a good set of S pistons and cylinders that I can just swap. Also looking for good E or S cams.
Thanks Ryan
Thanks Ryan
The S pistons and cams will be somewhat of a waste of time without enlarging the ports on the heads . 2.2 E's and T's had the same port size , so E cams and pistons might be a better option .
I have a like new set of 1969 911E 2.0 liter Mahle pistons and cylinders. Also I have a set of professionally rebuilt 1969 911E 2.0 liter cylinder heads that could be made into 1968 911S heads simply by enlarging the intake and exhaust ports. If interested PM me with your email address for details.
TIA
Henry
I have a nos set of 2.2 Mahle Biral piston & cylinders available. Pm if interested. cliff
I have a pair of 2.2T cams ground to E profile. I was going to use them on my 2.2T rebuild but got swayed into going mod-S. PM if interested.
