Hi Dave,
I have an engine that might help your data. Sorry, no car to match it to.
S/N 900740
Build# 640
Type# 901/01
Pairing # 666
Date 11/64
-Wade
Hi Dave,
S/N 900740
Build# 640
Type# 901/01
Pairing # 666
Date 11/64
-Wade
901/01
900 541
441
Par 496
Date 11/64
http://i41.photobucket.com/albums/e2...psdiuunknl.jpg
1968 911, VIN 11835153
Engine Type: 901/14
Engine Number: 3280702 (early Magnesium)
Build: 12315
I have updated the first posts with new data today. I also found what I strongly believe to be a typo in the build number of an engine:
901/14 3281505
This engine case is stamped 15958, but the serial # sequence places it at 15985; therefore I conclude that there was a typo error where the last two digits were reversed. Here there are 71 engines in a sequence of one type only; they should be in sync, but 3281505 would be badly out of sync at 15958.
901/14 3281463 15943
901/14 3281492 15972
901/14 3281505 15985
901/14 3281533 16013
Just updated the list with another dozen.
Here's mine.
901/14 3280414 11094
someone have more info, meg or al? Carb used on this engine should be Weber 40IDAP 3C or 40 IDA 3C?
That engine case is almost certainly aluminum. The magnesium cases didn't appear until early in the 12000 range. You can confirm by finding the casting part # below the oil return tubes ending in 101.xR and 102.xR; if the x is 0 then it is aluminum, and if x is 1, then it is magnesium. If the engine is stripped down, then there are other very useful numbers to find.
So next to the oil temp sending unit is is stamped 900406* so does this mean the 406th engine built
Actually no. They started at 900101. If you look for the build # you will see that it is 306. And that is the original engine. What is the paint code?
