Hello,
What is the original tip part color of a Bosch 001 212 002 starter which was used 4/65 up to 7/68? I assume the starter was black over all or?
Thank you.
Best regards
Claudius
Attachment 585169
Attachment 585170
Attachment 585172
Hello,
Thank you.
Best regards
Claudius
Attachment 585169
Attachment 585170
Attachment 585172
The starters were held by the mounting flange and dipped in a bucket of paint, I suspect to seal the electric side of the case. The unpainted end at the starter gear would range from 3/4” to a couple inches.
I agree about the technic.
If I zoom in the picture taken 1967, it looks like the 002 starter was completely black including the mounting flanges?
Attachment 585192
I've seen a lot of starters with no paint on the front , I would say this is the usual paint procedure , but as with most everything there are exceptions .
