Electric window harness
I need the 3 harnesses to put electric windows in a 73 chassis. This means the second generation harness that uses 5-pin switches, not the first generation 4-pin (the ones with the metal bezels).
There is a harness in each door, connecting to the front inner fender, and the cross-body harness that goes under the cowl.
We have all versions listed on our website and available from stock.
I have a good set for both doors pm sent
Thanks all, hoping to come in at less than new repro prices, but I do need the harnesses for the 5-pin (all plastic) window switches, not the earlier 4-pin (metal bezel switches).
