1 Attachment(s)
Pet Peeve - Improper use of Euro front signal lenses
Am I the only person that this bothers? I see it on all manner of expensive restored cars. People put the amber/clear euro lenses on US front turn signal housings. Looks silly, and seems like a big lack of attention to detail to me.
The whole idea of the bi-color lenses is so that the parking light (side light) is separated from the turn signal light. Parking light (in most of the world) is white (the clear section), and the signal light (again, in most places) is amber.
To do this the rest of the world got a different light housing with a divider that separates the two lighting functions, each section with its own single-filament bulb. The US housings don't have the divider, and have one dual-filament bulb to do both parking and turn signal functions.
It's easy to see when these euro lenses have been improperly used - since there is no divider, the clear section shows an amber reflection from the inside when the lights are off. And both the parking lights and the signals light the entire lamp (both sections) together.
Please people, if you want to use the euro-lenses, either modify or replace the light housings to match. Or just stick with the all-amber US lenses.
Wrong:
Attachment 564394
Correct:
https://www.early911sregistry.org/fo...2&d=1634964984
1 Attachment(s)
Euro Adapters Available Now
I posted this somewhere on the forum but I never posted it here. In case you missed the other thread, I have these Euro city light bulb holder mounts available now. I ordered the OEM blank metal plates and configured them myself.
Attachment 580671
I use white wire now, the same that the factory used. You will find them at the AC Shop - $118.00 a pair. It seems that the lack of a city light for the proper section of the Euro lenses bugged a lot of folks as I have sold lots of them. Easy to install as both turn signal housings, U.S. and Euro, have small prongs on the inside of the housings that they mount on.
Cheers,
2 Attachment(s)
Good Way to Start the Day
The owner who sent me the picture that I posted here just sent me some with the lenses removed. Thankfully the U.S./Euro converters are configured properly. It appears that my initial conclusion regarding the dividing line of the lens was correct. Big relief to me, I lost sleep over this last night.
Attachment 581619
Attachment 581620
