[QUOTE=Harvey Weidman;760
There were some ways* you could always tell if the car was originally delivered with the soft window so verification should be certain.
H[/QUOTE]
Few ways* I can think of is :
1. Does any of the SWT parts remain like tonneau cover or tensioners remain?
2. Do underside Targa bar still have visible cutouts left on its underside?
3. Do any of the interior targa bar stripped off interior body parts bear any correct clamp markings for tensioner handles?
4. Does past records/receipts that show work having the SWT conversion (if still exist)?
5. Does the conversion will include bodywork that covers up tonneau tenex clips holes?
6. Does interior rear seat areas bear markings of being bungled with conversion, including tenex snaps for rear delete/seat areas?
7. Does it show if some cars opted for adding additional rear seats.
8. Does rear window heater wire show a fresh/non factory connection? All SWTS might have wire in place, its just having its electrical, taped off.
9. Do the openings for 10mm bolts holding the tensioner handle so correct wear?
