4 post vs 2 post lift advice requested
Guys,
I want to put a 4 post lift in the garage to double the storage capacity. However, the only 4 post lift I can find is sized to store an aircraft carrier sized SUV. The footprint takes up most of the garage, which means that the refrigerator with the beer would have to go. So far I have not been able to find anybody with a 4 poster catering to the 911, early Mustang, Miata, MGB crowd.
So I am now considering a 2 poster, although it is not first choice. Here are my questions:
1. Can I use a 2 poster for long tern storage without causing any untoward damage (If I place the arms correctly under the car) to suspension components?
2. What issues do I want to consider other than conservation of space in deciding between a 2 poster or a 4 poster?
3. If I have enough garage height, what are the agruments for and against under bar and over bar 2 post models
4. Does anybody make a junior sized 4 post model that I have not discovered yet?
Thanks for the thoughts
John, member # 322
73 S with sporto
