... in the style pictured please.
*** update: found some, thanks! need 2 more please ***
I might have some, can you measure the length you need?
I need some for Solex 40PI if you have them to swap? Your pic looks like they are for a Weber Air Cleaner?
hello Jesse;
if I'm measuring this correctly the clip is 30mm long. sorry, no luck on Solex type. the only spares I have there would be venturi / choke.
thanks for offering.
jerry
Hé Jerry,
If I measure the spring plate (is that the word for it) they seem to be longer:
Attachment 580313
Attachment 580314
hi Jesse;
measuring with the same method I get 33mm. the slight difference is probably owing to curvature of the "plate".
I'm sure the shorter of the pair you posted is correct.
Ok! Send me a PM if you want to buy one of them!
Cheers,
Jesse
found some, thanks! need 3 more please.
two more please.
