7 Attachment(s)
FS: 911 Door Hinge Bolt, 999.509.001.02
These bolts were used from '66-Mid '72. They have the correct 12 point, triple square, XZN recess and replace the NLA:
WET '65-68 911 Fig 8/6 #3) 999.509.001.02 Cheese-head screw, M08x1.0x15 Qty: 12
Door hinge bolts '72): 900.075.085.02 Hexagon-head bolt, M8x20.
Material: Titanium, Gr 5 (6AL-4V)
Finish: As machined
Weight: 5.72 grams (4.36 grams lighter than OEM)
They come with the choice of several washers (#7) :
* 1 Washer, lock, split for 'standard' 911
* 1 Washer, lock, split for cap screws (non-OEM, but I think they look cleaner)
* 1 Washer, lock, Toothed for other models
* 1 Washer, lock, Belleville/Schnorr for believers
These bolts require an M8 XZN socket, preferably 3/8" drive, impact rated. Non-impact socket sets can be found cheaply on eBay (US seller, lifetime warranty). They can also used on the door striker bolts. An impact wrench, impact hammer, or 24" breaker bar will aid in bolt removal.
The bolt's price is $5.33 each ($31.98 per door set of 6, $63.96 per car set of 12).
Shipping within the US is by USPS First Class Mail (varies by destination, ~$5.00). Priority Mail is available for $7.20 (As of 2023 it is $10.20!).
Other parts available:
Key Words: XZN, 99950900102, N 0147074
