Hi all,
I'm looking for a set of four (4) Repa rear seat belt bolts and collars like the ones pictured here, but in better condition. Thanks.
Attachment 580985
Hi all,
Attachment 580985
I have some
can you tell me the overall length of the bolt, length of the collar on the bolt, and the length of the collars.
I will see if they are the same.
Dean
I am not home right now
I will measure mine on sunday and get back to you
Dean
Thanks. Here's a closeup of the bolt head if it helps.
Attachment 581456
I guess you need the one piece bolt with collar/washer, never seen rear seat belt bolts that used a separate washer. Rear seat belt bolts are the shortest REPA bolt available (except the one for the receiver, that one is even smaller, and with a thin head). BTW, I do only have the longer ones for the front seat belts.
Regards,
cees
I defer to your expertise. I don't know where the loose collar came from, then; maybe it sheared off the missing bolt?
Here a picture of the rear seat belt bolt. Easy to cut if you find only the long ones.
Otherwise these should be ok: https://www.ebay.com/itm/37428280594...3ABFBMwuaIwvdg
Regards, Cees
What I was calling a "collar" is more accurately called a "spacer." Got the parts I need, thanks all. Mods, please feel free to close the thread.
