It's amazing how rough some of these 914's can be....mine certainly was.
Antoine, you're doing a great job.
Keep up the steady work and you'll have a great driver in the end.
Love that you are going back with the original color too.
It's a good one.
Thanks to all for the support..I see that this thread is ok here so I will keep posting!
So, that was the next logical step..primer on the passenger side fender :D (and all around the windshield after taking it also to bare metal) :
https://www.thesamba.com/vw/gallery/pix/2219386.jpg
https://www.thesamba.com/vw/gallery/pix/2219389.jpg
https://www.thesamba.com/vw/gallery/pix/2219387.jpg
And I took care of a few holes on the driver's side firewall:
https://www.thesamba.com/vw/gallery/pix/2213144.jpg
https://www.thesamba.com/vw/gallery/pix/2213143.jpg
https://www.thesamba.com/vw/gallery/pix/2213142.jpg
https://www.thesamba.com/vw/gallery/pix/2213141.jpg
https://www.thesamba.com/vw/gallery/pix/2213140.jpg
https://www.thesamba.com/vw/gallery/pix/2213139.jpg
https://www.thesamba.com/vw/gallery/pix/2213138.jpg
https://www.thesamba.com/vw/gallery/pix/2213137.jpg
https://www.thesamba.com/vw/gallery/pix/2213136.jpg
For the bottom part, I will wait to have the body on the cart/body frame as not only the bottom of the firewall but also the floor is affected. More on that later :wink:
Before starting the body frame /hell hole fix, I wanted to check how the quarter is (part of me knowing I might have to cut it to repair right the right long).. Here the result, quite impressive..
https://www.thesamba.com/vw/gallery/pix/2216993.jpg
https://www.thesamba.com/vw/gallery/pix/2216992.jpg
https://www.thesamba.com/vw/gallery/pix/2216991.jpg
https://www.thesamba.com/vw/gallery/pix/2216990.jpg
So now I know it.. I will build from scratch that quarter panel and cut it, repair the long, weld my new panel.
Just for fun I made a small test panel to try the shape of the wheel opening:
https://www.thesamba.com/vw/gallery/pix/2219392.jpg
But I hadn't a large enough sheet metal piece to start on the quarter panel so I starte on my body frame..
Fresh metal came:
https://www.thesamba.com/vw/gallery/pix/2219385.jpg
Welded the long part:
https://www.thesamba.com/vw/gallery/pix/2219388.jpg
Rest will follow with all the fixations I planned (bumpers, engine, gearbox, front axle, back axle,..) to keep the body square du ring welding.
Stay tuned !
Antoine
1 Attachment(s)
Amazing work ! Fantastic. Here is some inspiration…1975 1.8 owned by a local lady since new until I purchased last year. Yours will look great.
Attachment 573689
Did you remove the foam from behind the sail panel? That’s what holds the water and helps the metal rot out from the inside.
Before removing the paint on the right rear quarter panel, I wasn't sure how to deal with it while repairing the hellhole. I knew cutting it would allow me a better access but cutting good metal is always a hard decision..
Well, from that point of view I got "lucky" :lol: because there is no good metal :lol:
Here without paint:
https://www.thesamba.com/vw/gallery/pix/2229193.jpg
https://www.thesamba.com/vw/gallery/pix/2229190.jpg
And I have a habit that I built(or make sure I have it) the part before cutting, to ensure I won't miss any measurement/positioning. So here we go !
Making my template :
https://www.thesamba.com/vw/gallery/pix/2229192.jpg
https://www.thesamba.com/vw/gallery/pix/2229188.jpg
And starting :
https://www.thesamba.com/vw/gallery/pix/2229201.jpg
https://www.thesamba.com/vw/gallery/pix/2229198.jpg
And after a couple hours:
https://www.thesamba.com/vw/gallery/pix/2229191.jpg
https://www.thesamba.com/vw/gallery/pix/2229185.jpg
https://www.thesamba.com/vw/gallery/pix/2229187.jpg
https://www.thesamba.com/vw/gallery/pix/2229200.jpg
I left the front part undone to be able to make a good door gap when it comes to that time.
So, now that this is done..cutting!
https://www.thesamba.com/vw/gallery/pix/2229196.jpg
Cheers
Antoine
I also removed the 47 years old fuel lines:
https://www.thesamba.com/vw/gallery/pix/2232630.jpg
https://www.thesamba.com/vw/gallery/pix/2232629.jpg
Stainless steel replacement is on its way!
Then I looked further on the outside part of the hellhole..which doesn't look promising:
https://www.thesamba.com/vw/gallery/pix/2229781.jpg
https://www.thesamba.com/vw/gallery/pix/2229780.jpg
https://www.thesamba.com/vw/gallery/pix/2229779.jpg
https://www.thesamba.com/vw/gallery/pix/2229778.jpg
And after checking a bit inside (quite a lot of layers in this badly repaired jack point..):
https://www.thesamba.com/vw/gallery/pix/2229782.jpg
There were some findings:
https://www.thesamba.com/vw/gallery/pix/2229783.jpg
And a lot of rust falling through:
https://www.thesamba.com/vw/gallery/pix/2229784.jpg
I did not want to fight forming too much thick metals so I made a small order to save me some time:
https://www.thesamba.com/vw/gallery/pix/2229785.jpg
So..time to cut really into this repair..
But before that, I took a bit of time investing in my future partner in crime..my 5 years old boy already wants to learn how to weld!
https://www.thesamba.com/vw/gallery/pix/2232631.jpg
Stay tuned
Antoine
