Alfa Brembo Calipers...what hubs?
Hi All,
So I've been working some new parts onto my 66 911 and thought it was a good time to fit the Brembo Alfa callipers as part of the swap. I got everything fitted up okay with new vented brake discs (on my original hubs). The car is on a real set of American Racing torque thrust mags. There's no clearance between the wheel and the calliper at all. So, I grabbed some stock steels I have to see if the wheel was a problem. The stock steel doesn't clear it either. I know it's supposed to be a plug and play swap. Is there a difference between the solid disc hub and the vented hub which is causing my fit issue? I know others are using these with no issue?
Many thanks
