I have just bought some 5.5" Group 4 TTs for my sons VW and they weigh just under 16 pounds.
The 5.5" are on sale at the moment. Quite like the look of them too.
https://live.staticflickr.com/65535/...d79ca1b4_c.jpg
Quick update. Finally got help over at American Racing. As it turns out, the new Torq Thrust wheels from American will not fit over early S brakes. Bummer.
I found one AR Torq Thrust D Wheel in excellent original condition. It had been in dry dark storage for over 45 years. I rubbed in a coat of Gibbs as a preservative.
15x6 size. A real magnesium wheel that weighs only 12.6 lbs.
Attachment 603351Attachment 603351 will try Gibbs on the one with corrosion
Attachment 603352. Oops meant this pic
I recently received my set of five NOS (yes, never been used) second gen 15x6 magnesium GTP wheels and I have a couple questions. First, what are y'all using for lug nuts? second, are tubes required with these wheels, or can I find valve stems that will seal correctly?
thanks!
Not sure if these nuts fit the magnesium rims - shown on the aluminium. I had some nuts machined for my ali.
https://www.tiporscheproducts.com/pr...rust-lugs-nuts
Also see here: https://www.early911sregistry.org/fo...hrust-Lug-Nuts
