Thank you but I have found the ashtray insert last year.
When i found a part I update the first post of this thread and I change the status from "wanted" to "found" in the table.
I also add a picture of the part I found.
Philippe
to the extent it matters, i responded that i have the wing glass with "D-02" and "AS2", but received no response. as stated, it is the glass, only, without frame.
the post appears to indicate that you are still looking.
i'm certainly not offended, but it appears that you are very careful in your search, and i wanted to help if possible.
Hello Mike,
I sent you my reply below on March 27, 2020 to which you replied the same day with this text: "okay. got it."
Best regards,
Philippe
Attachment 585972
Here is the picture of your glass you sent me:
Attachment 585973
You have my sincere apologies. You are correct. I had failed to recognize the distinction.
I do have the ash tray insert in my spares. Maybe it can help the next guy?
