901.101.101.5R 901.101.102.7R
The right case half changed. I've no idea if 901.101.102.5R or 901.101.102.6R ever existed.
901.101.101.7R 901.101.102.7R
The final incarnation of the magnesium case. It was introduced in mid 1973 production and used to the end of the 2.7 production.
901.101.101.7R 901.101.102.7R AL
A small run of diecast aluminum cases was made for racing engines as the magnesium case was proving fragile. Photos taken by Steve Weiner of Rennsport Systems.
911.101.103.0R 911.101.104.0R AL
A revised design in aluminum for racing purposes appeared in 1973.
http://www.early911sregistry.org/for...ead.php?t=8724
930.101.103.4R 930.101.104.4R
The first of the aluminum "Turbo" cases.
The most useful data so far. I will continue to update as data comes in.
Anyone that can add to, or update the data, please post.
YEAR Type Serial # Left Case Right Case Build # Date
1965 901/01 902086 901.101.101.01 901.101.102.01 1986 1965
1966 901/01 902586 901.101.101.01 901.101.102.01 2486 1965/06
1966 901/01 903519 901.101.101.01 901.101.102.01 3419 1965/08 & 09
1966 901/01 903581 901.101.101.01 901.101.102.01 3481
1966 901/01 903868 901.101.101.01 901.101.102.01 3787 1965/08
1966 901/20 906157 901.101.101.10 901.101.102.10 ~4800 sandcast MG
1966 901/05 909018 901.101.101.01 901.101.102.01 5071
1967 901/02 960003 901.101.101.02 901.101.102.01 5224
1967 901/02 961808 901.101.101.0R 901.101.102.0R 8507
1967 901/02 962170 901.101.101.0R 901.101.102.01 9195
1968 901/02 4080029 -------------- 901.101.102.01 9272
1968 901/02 4080261 901.101.101.0R 901.101.102.0R 10111
1968 901/14 3280442 901.101.101.0R 901.101.102.0R 11233
1968 901/10 4490002 901.101.101.1R 901.101.102.1R 11474 MG proto
1968 901/17 no serial -------------- 901.101.102.0R 11771 AL
1968 901/14 3280910 901.101.101.1R 901.101.102.1R 13352 MG
1968 901/14 3281356 901.101.101.1R 901.101.102.1R 15372
1968 901/02 4081419 901.101.101.1R 901.101.102.1R 15415
1969 901/10 6390297 901.101.101.2R -------------- 17421
1969 901/11 6298522 901.101.101.2R 901.101.102.1R 24334
1969 901/09 6292143 901.101.101.2R 901.101.102.1R 25815
1969 901/16 6196718 901.101.101.2R 901.101.102.1R
1969 901/09 6290126 901.101.101.2R 901.101.102.1R
1969 901/11 6298546 901.101.101.2R 901.101.102.1R
1970 911/03 6102207 901.101.101.3R 901.101.102.2R
1970 911/02 6300564 901.101.101.2R 901.101.102.1R
1970 901/38 6404153 901.101.101.3R 901.101.102.2R
1971 911/03 6110455 901.101.101.3R 901.101.102.3R
1971 911/03 6110458 901.101.101.3R 901.101.102.3R
1971 911/03 6111222 901.101.101.3R 901.101.102.3R
1971 911/07 6115913 901.101.101.3R 901.101.102.3R
1971 911/07 6116842 901.101.101.3R 901.101.102.3R
1972 911/51 6120527 901.101.101.4R 901.101.102.3R
1972 911/51 6120770 901.101.101.4R 901.101.102.3R
1972 911/61 6129111 901.101.101.4R 901.101.102.3R
1972 911/52 6220655 901.101.101.4R 901.101.102.3R
1972 911/57 6520935 901.101.101.4R 901.101.102.3R
1973 911/51 6130126 901.101.101.5R 901.101.102.4R
1973 911/51 6131319 901.101.101.5R 901.101.102.7R
1973 911/51 6131434 901.101.101.5R 901.101.102.7R
1973 911/91 6133470 901.101.101.7R 901.101.102.7R
1973 911/91 6133858 901.101.101.7R 901.101.102.7R
1973 911/52 6230113 901.101.101.5R 901.101.102.4R
1973 911/62 6239200 901.101.101.7R 901.101.102.7R
1973 911/53 6330398 901.101.101.5R 901.101.102.4R
1974 911/92 6141648 901.101.101.7R 901.101.102.7R
1974 911/77 6840161 911.101.103.0R 911.101.104.0R AL
One of the most interesting cases is the sandcast magnesium case used in the 906.
Thanks. Details like this will be added as research progresses. I'll also add annotated photos depicting the various changes. Any and all help gladly accepted.
