I remember being in John’s shop many years ago, early 90’s, and he had a red 1989 C4 there for finally making larger pipes for larger displacement engine. Never happened to my knowledge.
there is a 41 mm in process right now !
its not as easy, as you might think
here just some random pics of the hole tube process only !!!
JP group is one of the largest exhaust manufactors ( for your daily driver ) , so bending tubes, is not the problem
Once bended, the ends of the tubes are send to be milled , and just by changing the diameter a bit ( for the larger engines ) ,
the whole process must be changed by the engineers with new jigs , tools etc , but once finish
they are of the get washed , to get rid of all the dirt and grease
then they get welded all together and EACH gets pressure tested, in the fish tank, for any holes to check
This is just phase 1 ... more to come
Marek
Can you share what improvements have been made? I think I got an early set of the JP SSI heat exchangers. I had a minor fitment issue with one heat exchanger hitting the time chain housing, but other than that, no complaints, but I had nothing to compare them to.
Neil
Hi Neil
Well if its on your 73 cars no really inprovements beside they got more sportwelds now , there where nothing wrong on the version with a few less spots
well when they just took over they had some fitting problems , but nothing serious that a skilled mechanic couldent fix
I must say, coming in from the side as a "new" guy I must say , and what they tell me ,is the last 2-3 years they had like 3 cases
I post more of the process later on ,where you guys can see how detailed the work is and how they test fit EACH
Marek
Hi Guys
Step inside a 3D tour of the assembly hall at SSI in Denmark
https://my.matterport.com/show/?m=tjNibkPKZz8
I am sure it would be a joy, for John to see his old machine park, is still working like a Swiss watch
Remember to follow SSIexhaust on Instagram for the latest news and dont forget to TAG us on your build
SSIexhaust
Martin Owner of JP Group / SSI found a cool picture in his old stack
Taken in San Fransisco the 14 of August 2012, that was the official date, where he bought SSI from John Daniels
Picture is taken (and shaken :-) short after ,they both have signed the deal ,
He says hallo to John , if some of you guys ,are still talking to him, Hope he is doing well
Hi Guys
We got a 41 mm ready for you guys in the early 2021 ( febuary )
We are doing some testing right now , we got a perfect fit, and we are happy with the result
pricing will follow in the new year
you are welcome to order by sending me a e-mail at early911parts@gmail.com
and I will keep you posted once they are ready
we got a bunch off new SSI stuff comming in spring 2021
so follow us on instagram SSIexhust
and I will offcause post ,the news here also for you guys
Happy hollidays and stay safe
from SSI- Denmark
Marek & Martin
That's great news. As soon as you can ship let us know. I need a couple pairs.
