From the dashboard forward the steering, suspension and brakes are installed and torqued..........
dAttachment 597997
dAttachment 597997
Must be getting close to the maiden voyage!
Really coming along nicely.
hung the fender with 2 screws just so i could seeAttachment 598022
Attachment 598023
The Mouse Hole.....Attachment 598399
Attachment 598400
Attachment 598424
Time to build the dash board
Sand blasted and painted...Attachment 598891
also the Targa specific under dash suport...
Attachment 598892
The front sway bar arms should be yellow zinc , your car is deserving of the correct details .
ok Richy
looking at my upholstery options, or should i say the inability to find red elephant hide
greased the rails of a slide down an alternate path.
i can and will get back on path with the yellow zinc.
thank you Richy
mock up of dash trim
the lower piece is out of the dash kit (i Have the whole kit) .... I have to decide if I want to sand them out with 180# and take them thru the polishing sequence
none of the pieces are attached, just the pins hanging in the holes and upper pieces are from original (not to be used)
The glove box and ash tray opens and closes perfectly with very good gaps all thru-Attachment 599351out the dash
Here is the lower dash knee bump being readied for skin
And the lower Targa specific support piece being wrapped in Perlon
Attachment 599446
Attachment 599447
