1 Attachment(s)
Can the minimal gauges be upgrade to full S spec?
I'll be getting a 1973.5 911T in a few months and one of items I noticed was the reduced instrumentation on this car.
The 1st gauge from the left only has fuel level and not the oil tank level.
The next gauge moving right only has oil temp but not the oil pressure.
Certainly I can buy better gauges or get mine modified.
Do most car's wiring harnesses support this additional instrumentation.
In other words....are the necessary wires behind the dash and in the engine compartment to add the oil tank level and oil pressure readings?
Obviously I'll need some senders (oil pressure and oil tank level) as well.
Is this a fairly straightforward job to take on?
