1 Attachment(s)
Seat Belts Hardware
I need:
4 hexagon head bolts PN 90180314600 (see picture for reference)
5 spacer tubes PN 90180311440 (see picture for reference)
2 Short hexagon bolts (don’t have part number, see picture on the far right) they are the one to secure the seatbelt receiver to the set bracket
1 Repa Seatbelt B pillar mounting “hanger” (don’t have part number, see picture on the far left)
Attachment 588404
Hello,
Can you specify the collar OD and length to the bolt, also spacer OD/width. Need to check my parts bin. I have a spare B pillar hanger for sure.
Regards,
Cees
I’ve found the B pillar hanger and longer hex bolts.
Still need the spacer tubes PN 90180311440 (OD 13.7mm, 5.6mm)
Still need 2 short hex bolts
1 Attachment(s)
I have couple of spacer tubes but not the exact size. See pic. I have some short bolts but those are cut back 7/16''x 25mm ones. They will do the job though.
Cees
I have a few dozen New old stock B post hangers if yours are not up to scratch.
Thank you fourteenten, PMed you
2 Attachment(s)
Hello,
I am also remounting my 69 Targa and looking for some similar parts:
- 31 2 x 90180314600 - Hexagon bolt (it is specific for the Targa)
- 32 4 x 90180314700 Washer
- 33 2 x 90180314400 Washer (specific for the Targa)
- 34 2 x 90180311440 Spacer pipe (specific for the Targa)
Attachment 617161
I am also looking for this kind of rubber (in the red circle), not referenced on the PET:
Attachment 617162
I may have one spacer with the ID for the bolt and the OD for the hanger from a 69.
If interested, PM me so I will remember when I get home in a couple of weeks.
Steve
1 Attachment(s)
Hello Renaudtwingo,
I have 4 of the plastic beveled washers (VW), not in black as used in our Porsche's but in same size and thickness. Also, two metal spacers not equal in size but should work.
Regards,
Cees
