Hello, engine in subject is currently disassembled.
Case 2.2 mag 911/07
bore 84 stroke 66 ( not counterbalanced crank)
cylinders and pistons (2.4S)
rods, oil pump, internals
heads, cams, cams housing etc
asking $5.5k
Case 2.2 mag 911/07
asking $5.5k
Click Edit Post
Click Go Advanced
Click Manage Attachments
Upload photos and close pop-up
Save changes
Let me know if you need any additional help
Crankshaft 911T, 66mm noncounterbalanced
Camshafts 911T #901105133 0R
Heads 911T not pictured. Measure 46mm intake valve and 40mm exhaust.
Before disassemble was tested by G.Kirschner for compression and leak down.
145-150. 2%-2%
150-150. 2.2%-2.2%
140-140. 2.4%-2%
^^^^ great pics!
Few more shots....
What was the reason for the teardown?
Engine came out off my 911 T/R. Based on performance and feel, I was curious about internals. Original T/R engine wasn't recovered so curiosity took over.
This for sale motor in particular besides what in photos comes with alternator, starter, flywheel, clutch, distributor, engine tin metal, valve covers, chain box covers, rockers, camshafts.
Not sure but engine harness and spark plug wires are present too.
Heat exchangers are gone but megaphone pipes set are still available.
Parts off of this engine where listed here and all are available from this post. Available to go together with engine in subject.
https://www.early911sregistry.org/fo...on-Box-Starter
$5K for all above .....
to the top. Open to reasonable offers.
