3 Attachment(s)
Steering Wheel Hub ('64-73.5) Different Spline Count?
Clearing out the garage I collected 3 VDM four spoke steering wheels with two different size spline counts.
#1- is 24 tooth spline w/22mm ID; 400mm wheel (has a steel ring around it)
#2- is 40 tooth spline w/20mm ID; 400mm wheel
I have a '66 911, '69 911 and a '72+/- 914 and they all take the #2 hub (40x20mm ID)
How many different types of spline/hub configurations are there that used the early VDM 4 spoke wheel??
I thank you in advance.
pic#1= 24x22mm 400mm wheel
pic#2= 40x20mm '69 911 400mm wheel
pic#3= 40x20mm '72+/- 914 380mm wheel
