Weather stripping question
Hi all,
I will replace the outside seal between targa loop and soft window. While I am at it, I am thinking on replacing the seal on the front (Inside) of the bar aas well as window channel and door slot felt/ seals.
The stuff I ordered for Stoddard's has a "weird" modern look so I am wondering what actually was original compared to the replacement stuff. Can you guys advice regarding what is/ was original and how you solved similar tasks?
- The Inside seal around the Targa loop seem to be of grayish color on the bottom with a funky pattern/fabric, the replacement seal black all around
- The replacement channel felt looks very soft and very black - The stuff on my car (Most likely original or stoneold) is also more "grayish" and rougher felt, though might be faded
Thanks much,
Mike
