I’ve found multiple posts addressing the correct bolts to attach the seat rails to the floor, including the use of split ring lock washers beneath each bolt. Apologies if I’ve missed this, but do the rails in turn attach to the bottom of the seat pan with similar bolts and lock washers? If it matters, I have a 1972 with the standard comfort seats.
Mike
1972 911T coupe
Member #4294
